Naxterra
Mar 11, 2018Apprentice
Questions before buying XR500
Hello I moving to a new flat and I will have 900mbit symmetrical internet speed. Internet connection will be provided via ethernet cable and I won't have access to ISPs main router below apartmen...
- Mar 12, 2018Please keep it civil. We're here to give Naxterra advice on what router to purchase.
Hi Naxterra, I also work for Netduma (creators of DumaOS). If you did end up purchasing the XR500 I would also very likely be the one giving you technical support on the forums should you need it.
Out of the options you listed the XR500 as far as I am aware is the only one that has actually built an entire router operating system from scratch. That means we are able to develop new features very quickly. We have a massive roadmap in front of us and we haven't even hit the tip of the iceberg yet.
As others have said the XR500 can handle all your devices no problem! Regarding NAT for PS4, UPnP, Port Forwarding or putting it in the DMZ will open the console's NAT.
Netduma_Jack
Mar 11, 2018NetDuma Partner
All those models have great WiFi so from a hardware side of things you can’t go too wrong.
But on software - the XR500 is miles ahead of the others because of DumaOS. It has many unique features, such as the Geo-Filter which will guarantee nearby servers when you play on your PS4. It also has the best QoS which prevents local devices from causing congestion. There are many other features too - check out YouTube for a review. Here is one that was posted yesterday: https://youtu.be/tb4HjaKStuw
Disclaimer: I work for the developers of DumaOS so please take the time to read others opinion e.g. Amazon reviews or journalists review.
