Compoza_'s avatar
Compoza_
Luminary
Mar 03, 2021
"R-app is not loaded yet " on XR300
None av the current troubleshootings works to boot up R-App Store, I have rebooted and factory resetted the xr300 router, still "the R-app is not loaded yet" pops up on the screen. What do to? Regard...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Mar 03, 2021
    Yes that is good thank you. Those will not appear as features on the router to be used, that is normal.
