Compoza_
Mar 03, 2021Luminary
"R-app is not loaded yet " on XR300
None av the current troubleshootings works to boot up R-App Store, I have rebooted and factory resetted the xr300 router, still "the R-app is not loaded yet" pops up on the screen. What do to? Regard...
- Mar 03, 2021Yes that is good thank you. Those will not appear as features on the router to be used, that is normal.
Netduma-Fraser
Mar 03, 2021NetDuma Partner
On the System Information page, in the Rapp panel option menu change the retry amount to 5 and then reboot the router. Do they load properly then?
Compoza_
Hi! I tried it but R-App Store and System manager still don't show up :(
