Tendrop
Aug 04, 2019Aspirant
R-App is not loaded yet, please try again in a minute.
Gents - After installing the recommended firmware I'm getting the "This R-App is not loaded yet, please try again in a minute". I've rebooted routed a couple times but it still happens. Thanks f...
Tendrop
Aug 05, 2019Aspirant
FURRYe38 wrote:Has anyone asked a forum moderator for the beta? The beta helps with the apps and UI.
Thanks Furry - Yes I installed the Beta FW on Saturday. Started getting the R-Apps error message thereafter. I need to reboot to remove the error but it comes back after a little while. The beta FW was suggested by a Guide because of my original Post regarding the LAN disconnect issue having every other day or so. The R-Apps madness was not as frequent on the other FW but it would show up now and then. Just a head scratcher all around for a $500 router. BTW, I've never seen the fans spin on this thing either so maybe it's a lemon. I hope other people are having better luck with it. When it works it does its job. Mine has been high maintenance since purchase in March.
Aug 06, 2019Guru - Experienced User
Post your experiences with the beta over on the beta forum so NG keeps on this.
Was a factory reset and setup from scratch performed after loading the beta FW?
What browser are you using? Does FF or Opera exhibit the same thing?
- TendropAug 06, 2019Aspirant
FURRYe38 wrote:Post your experiences with the beta over on the beta forum so NG keeps on this.
Was a factory reset and setup from scratch performed after loading the beta FW?What browser are you using? Does FF or Opera exhibit the same thing?
Will do and, Yes, I did a factory reset (erase through OS) and setup from scratch after loading the beta FW. That was Donovan's direction.
