beemir
Jul 27, 2020Star
R-App Issues on XR500
Hi everyone, before I get into the nitty gritty, let me say that I purchased this router in December 2018 and it has been fine until around the past two months or so. At first the problem wasn't as p...
Netduma-Fraser
Jul 27, 2020NetDuma Partner
DumaOS 3.0 will fix this issue, it's in beta so bugs are still likely to happen but overall yes we're confident we'll be able to resolve this - hopefully once and for all. I will PM you with a suggestion and see if that helps potentially, I've just thought of it but requires some tinkering.
- beemirJul 27, 2020Star
Hi, as requested I tried what you suggested but it did not work. There is something interesting that I noticed, that may or may not give you more insight? I took a screenshot of it. Let me know where I can send it (PM or otherwise).
- Netduma-FraserJul 28, 2020NetDuma PartnerAh that's disappointing. Sure that would be great, just reply to my PM.
- beemirJul 28, 2020Star
Done. I replied to your PM with a link to the screenshot.
