Mrpenguinz
Mar 28, 2021Aspirant
R-app not loading.
I've been trying to fix this problem for little over a year now. I usaully get annoyed after trying what's recommended and forget about it. My issue is since i've bought this router i've had trouble ...
Mrpenguinz
Mar 31, 2021Aspirant
I'm using Firmware Version XR700 V1.0.1.38.
Netduma-Fraser
Mar 31, 2021NetDuma Partner
Go to the System Information page on the router and in the Rapp panel options change the number of retries to 5. Then reboot the router from the interface and see if it is better then.
- MrpenguinzApr 01, 2021Aspirant
It's set to 5 currently and they still never load.
- Netduma-FraserApr 01, 2021NetDuma PartnerUpgrade to the beta firmware and then factory reset after for a fresh install and see if that resolves the issue please.
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/XR700-DumaOS-3-0-Beta-Firmware/m-p/2019958- MrpenguinzApr 01, 2021Aspirant
I downloaded the beta, but all gave me is something that said "the image disc file is corrupted". What am i suppose to do with this?
