AntOneK
Aug 13, 2021Aspirant
R Apps
I've been having this r apps not loading now for almost a year and I can't find any solutions. any help on this?
AntOneK
Aug 14, 2021Aspirant
this didn't work at all. The problem still continues to happen. Almost been a year and this has been a problem, at this point should I just invest in a new router?
Netduma-Fraser
Aug 14, 2021NetDuma Partner
What firmware version are you on currently, are you using the beta?
- AntOneKAug 15, 2021Aspiranti am using 1.0.1.34
- Netduma-FraserAug 15, 2021NetDuma PartnerIs that the beta version or the normal version? Do you have Ping Heatmap etc?
