imza6666's avatar
Jan 26, 2020
R6700v3 wifi spottiness
My router has issues with its 2.4ghz band and occasionally its 5ghz band. I used a wifi analyzer and saw that I had neighbors competing for the same default range, so I moved my 2.4ghz band to 11 and my 5ghz band to 100. The wifi still cuts out often in the morning, usually on 2.4ghz but sometimes 5ghz as well.
I posted this thread a while ago, and disabled the Netgear Armor per their advice, which solved this same problem previously: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R6700v3-loses-internet-daily/m-p/1834783#M144177
It is now expired so it was already off.
