StevoKofo
May 25, 2019Follower
R7000 - AC1900 Configuration help
Hello all, I need help configuring my router for the best options to support a household that has 2 gamers often playing at the same time on two different Xbox 1X's. My router is the Nighthawk AC190...
May 26, 2019Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
