fraz51
Aug 04, 2019Aspirant
R7000 internet keeps crashing
R7000 internet keeps disconnecting
Aug 04, 2019Guru - Experienced User
Are you using the R7000 or R7000p which is in your model listing?
Firmware on it?
Modem you're using?
More details help. Is it wifi disconnection, loss of ethernet connection, what exactly is going on?
- Netduma-FraserAug 06, 2019NetDuma PartnerYou may find more answers if you post in the correct forum for your router: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
- fraz51Aug 06, 2019Aspirant
R7000
Firmware: V1.0.9.88_10.2.88
wifi and internet crash
