HikingPlane0
Mar 27, 2020Aspirant
r7000 The firmware is not compatiable with your router. Error code -2.
I am trying to move my r7000's firmware from V1.0.9.88_10.2.88 to V1.0.9.32_10.2.34 and I keep getting this error: "The firmware is not compatiable with your router. Error code -2." I have a Motorola...
- Mar 28, 2020
a couple things there.
1. The MB8600 is a modem router combo device. Is it in modem only/passthrough mode? or the netgear in AP (access point) mode?
if not, you're in a double nat. That can cause issues/slow downs.
https://kb.netgear.com/30186/What-is-Double-NAT
2. The agreed upon stable version for the R7000 is 1.0.9.42. When you download it, make sure to extract it. Many don't extract the file.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
HikingPlane0
Mar 28, 2020Aspirant
My modem is actually a cable only modem and not a modem-router so I did not have to do anything with that BUT I tried downloading 1.0.9.42 and it appears to have installed without a hitch (unlike 1.0.9.32) so I hope my problem is fixed and will update this post if it does not. Thanks for the help.
Mar 28, 2020Guru - Experienced User
Your right. Sorry, just had a similar motorola so didn't look it up.
