teckart
Apr 17, 2019Follower
R7000 WiFi schedule issues
I have the scheduler enabled. Every morning I have to maually turn on router. I then login and go to the "Advanced" tab, I select "Advanced Setup", "Wireless Settings." Then log-in go in and resel...
Apr 17, 2019Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
teckart wrote:
I have the scheduler enabled. Every morning I have to maually turn on router. I then login and go to the "Advanced" tab, I select "Advanced Setup", "Wireless Settings." Then log-in go in and reselect "enable wireless router radio" and select apply. The next day this "enable wireless router radio" is unselected. This is what I do EVERY morning. My time zone is correct, the "turn off wireless router by schedule" is selected and the schedule to turn off is 11:00 p.m. - 6:00 a.m. Why am I having to go in daily to select "enable wireless router radio"?
schumaku
Apr 20, 2019Guru - Experienced User
teckart R7000 firmware version? Time zone and DST config correct? I'm a little hesitant to push towards the latest firmware as this is known problematic (nicely said). If basic features like these schedules simply don't work, ChristineT Christian_R where is Netgears QA?
Moderators can move threads easily - much better than having lots of duplicate if people re-post in other sections, and mods are moving things later on. However, the moderators are not really on full duty - same applies to the (not) banning and handling of Spam and Scam.
