NickEverly
Mar 29, 2020Aspirant
R7000
internet tab is greyed out in netgear genie routerlogin page. trying to change DNS address
Mar 29, 2020Guru - Experienced User
do you have it setup in AP (access point) mode?
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
- NickEverlyMar 29, 2020Aspirant
yes i'm assuming i do because under the Genie banner in yellow it says "operation mode: access point". do i need to change it or turn it off, if so how?
i did this, but not sure if that's how you turn it off/disable:-
->wireless tab->unchecked the boxes for SSID connections (i believe that's what they were called, i'm doing this by memory) unchecked boxes for both the 2.5MH and 5MH option. but that didn't help all it did was not allow me to access the internet from the router wifi signal. thank you.
- plemansMar 29, 2020Guru - Experienced User
Usually if your router is in ap mode, its because there's another router on the network. Probably your isp's device.
Its done to prevent a double nat.
If you need to change the dns settings, you'll want to log into your isp's modem/router and change it there. (since the netgear's in ap mode).
- NickEverlyMar 30, 2020Aspirant
i got login and pw info from my isp and can now log into my modems interface page. what do i need to change in this modem page to not have it be double nat?
