prmorales
Dec 05, 2019Follower
R7400 AC2600 Smart WiFi Router
How do I know my router has the latest firmware version?
Dec 05, 2019Guru - Experienced User
the firmware should be in the top right corner.
Or you can find it on your status page of the router.
You can compare this to the listed firmware for your router in your devices support page.
should have stated top right corner when you're logged in through the browser.
this would also be the forum for your device
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
