seryms
May 26, 2020Aspirant
R7800 / AC2600 antenna replacement
One of the four antennas just broke and the wire got torn. My router is R7800 / AC2600 Nighthawk X4S. Where can I order a replacement? I have been trying Netgear's (800) number but I cannot even t...
May 26, 2020Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
seryms wrote:One of the four antennas just broke and the wire got torn. My router is R7800 / AC2600 Nighthawk X4S. Where can I order a replacement? I have been trying Netgear's (800) number but I cannot even talk to somebody to place an order because my warranty ran out. Thank you in advance.
