jpiszcz
Feb 23, 2019Aspirant
R7800 1.0.2.62 firmware BREAKS Netatmo Weather Station
If you use a Netatmo WeatherStation, beware, the 1.0.62 firmware update breaks connectivity for the device. I've updated every version since the beginning, never had an issue. However, with 1.0.62,...
Feb 23, 2019Guru - Experienced User
Please post about this here in this forum for the R7800:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Let them know what your seeing.
You should do a factory reset after loading new fw and setup from scratch to see if this helps solve the problem. Problem maybe the routers in a bad state after a FW update.
Good Luck.
jpiszcz wrote:
If you use a Netatmo WeatherStation, beware, the 1.0.62 firmware update breaks connectivity for the device. I've updated every version since the beginning, never had an issue. However, with 1.0.62, I can no longer connect to my weatherstation, previous versions were working fine. Has anyone else run into this issue?
Attached is a photo of Internet traffic that the Netatmo uses, post-upgrade it dropped to 0 (can't connect/issues)..
