ababoo
Apr 20, 2019Aspirant
R7800 Firmware v1.0.2.62 - DO NOT UPDATE: BUGGY FILE SERVER
The latest firmware update (v1.0.2.62) introduces a bug which causes the file server to shutdown after 2-3 minutes of use. The only way to get it working again is to reboot the router.
It seem...
Apr 22, 2019Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
It seems like there are a lot of bugs with this version of the firmware. Netgear really should pull it down from the site.
