jachcck
Apr 18, 2020Aspirant
R7800 router, no connection after reboot
No auto connection after firmware update to 1.0.2.68 Router r7800 cannot connect to internet automatically after reboot. I can only make it connect to unplug the lan cable and reconnent it. How ...
Apr 19, 2020Guru - Experienced User
what modem is it connected to? (model?)
- jachcckApr 20, 2020AspirantNo modem. Just directly plug the lan cable.
Pretty sure is the firmware problem. It was only happened when i updated the newest version.- plemansApr 20, 2020Guru - Experienced User
It might be the firmware. Anytime there's an issue after a firmware upgrade, a good first step is to factory reset and re-install the router.
If that doesn't fix it, you can try downgrading it.
The other thought was that ethernet connection is coming from somewhere. you haven't said a word about it. does your isp have an ONT, a router that serves the whole community, whats going on there? maybe the ISP or whatever's setup made a change to what it allows to connect or how it allows them to connect.
- plemansApr 20, 2020Guru - Experienced Userbtw, this is the forum for the R7800
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
