jachcck
Apr 18, 2020Aspirant
R7800 router, no connection after reboot
No auto connection after firmware update to 1.0.2.68 Router r7800 cannot connect to internet automatically after reboot. I can only make it connect to unplug the lan cable and reconnent it. How ...
jachcck
Apr 20, 2020Aspirant
No modem. Just directly plug the lan cable.
Pretty sure is the firmware problem. It was only happened when i updated the newest version.
Apr 20, 2020Guru - Experienced User
It might be the firmware. Anytime there's an issue after a firmware upgrade, a good first step is to factory reset and re-install the router.
If that doesn't fix it, you can try downgrading it.
The other thought was that ethernet connection is coming from somewhere. you haven't said a word about it. does your isp have an ONT, a router that serves the whole community, whats going on there? maybe the ISP or whatever's setup made a change to what it allows to connect or how it allows them to connect.
- plemansApr 20, 2020Guru - Experienced Userbtw, this is the forum for the R7800
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
