turboSHIZZLE
Jan 31, 2020Aspirant
R8000 slowed download speeds
My download speed is supposed to be at 100mbs but it's only 2mbs. Upload speeds are fine at 10mbs. Tried factory resseting, had the company come look and they said they get full speed when hooking dir...
Jan 31, 2020Guru - Experienced User
do you get full speeds when you directly connect to the modem? Thats the question. Not your isp.
What device are you testing with?
Are you testing 2.4ghz speeds or 5ghz speeds?
Are you using smart connect?
What firmware is on the router?
many say that factory reset but just click the button. Did you push and hold while the device was powered up? Its usually 7-15 seconds to factory reset it.
- turboSHIZZLEJan 31, 2020AspirantI tested the speeds myself with a speed test app and through my Xbox on both 2.4 and 5ghz. Not using smart connect. V1.0.4.46_10.1.63 is the firmware. And I held it for 15 seconds to factory reset.
- turboSHIZZLEJan 31, 2020AspirantAlso hardwired directly to my Xbox.
- plemansJan 31, 2020Guru - Experienced User
What speeds to YOU get hardwired to the modem?
And the speeds hardwired into the router?
- turboSHIZZLEJan 31, 2020AspirantI get up to ~20mbs on wired.
