Ortizbrian33
Jul 28, 2020Aspirant
R8000p Nighthawk random disconnections and lag
Not sure why but these past couple days the wifi has been beyond bad. Not all the devices can connection to it, and ISP said they didn't find anything wrong on their end. I did attempt to find some so...
Ortizbrian33
Jul 29, 2020Aspirant
Brand new device. Was working fine for the first 2 to 3 weeks. Then recently the wifi has been **bleep**ty. Random disconnections, slow speeds when devices can connection, or devices can't find the network. Worst part is that it says there is internet, but it's super slow. And the plan i pay for is above 600 mbps. It's frustrating lol.
The modem I have is the CM1100 from netgear since Xfinity said it was compatible.
Jul 30, 2020Guru - Experienced User
Are you using WAN port aggregation? If so, disable it on the cm1100 and the R8000P.
Wan port aggregation has been nothing but issues with consumer devices and if you don't pay for >1gig speeds, its not beneficial.
Does it impact wired speeds?
Do you have a screen snip of the cm1100's cable connection page and logs? it'd suck to troubleshoot the router when it was a line issue.
- Ortizbrian33Jul 31, 2020AspirantRight now I'm wiaitng for support to contact me back. The router and modem is in my moms room. She is out rn and I can't get in since she locked her door.
I did was support told me to do and changed some setting like MTU, channels, nd related steps and reset the router and modem. But it worked for a little bit then went back to he bad stuff. I'm rrtinf to work remotely and help out and it's preventing me from doing that. It's terrible. Barely can get a page to load. And the connection doesn't want to work. Honestly feels like a waste if money buying the router for 300 just for these issues to happen. I dont even think i can return jt which is the worst part.
