botzz28
Feb 05, 2024Tutor
RANDOM FACTORY RESETS!
Hey all This XR1000 has been a nightmare. Long story short. My router is literally factory resetting at random times. If my power goes out it hard rests and deletes EVERYTHING. Also if I unplug it or...
Netduma-Fraser
Feb 05, 2024NetDuma Partner
Make your settings changes then reboot from the interface, this should act as a hard save so if its unplugged at a later date or loses power etc settings should be saved
- botzz28Feb 05, 2024TutorWhat do you mean make settings change to hard save ? Can you explain a little further? I had to reconnect my entire house 2-3 times already I’m going crazy lol thank you !
- Netduma-FraserFeb 05, 2024NetDuma Partner1. Change the router settings how you want them set.
2. Reboot from the interface - this will act as a hard save- botzz28Feb 05, 2024TutorSo I can reboot through the settings in Duma OS after connecting every and changing settings and it will act as a hard save ?
