botzz28
Feb 05, 2024Tutor
RANDOM FACTORY RESETS!
Hey all This XR1000 has been a nightmare. Long story short. My router is literally factory resetting at random times. If my power goes out it hard rests and deletes EVERYTHING. Also if I unplug it or...
botzz28
Feb 05, 2024Tutor
What do you mean make settings change to hard save ? Can you explain a little further? I had to reconnect my entire house 2-3 times already I’m going crazy lol thank you !
Netduma-Fraser
Feb 05, 2024NetDuma Partner
1. Change the router settings how you want them set.
2. Reboot from the interface - this will act as a hard save
- botzz28Feb 05, 2024TutorSo I can reboot through the settings in Duma OS after connecting every and changing settings and it will act as a hard save ?
- Netduma-FraserFeb 05, 2024NetDuma PartnerYes exactly
- botzz28Feb 05, 2024TutorHow will I know if the reboot hard saved the WiFi settings and devices and everything? Any way to tell?
