IBTwist
Oct 12, 2020Aspirant
Random, Persistent Router Disconnects (XR500 with ATT Fiber and BGW210-700)
Hey fellow users, Been gaving some really annoying issues with my new XR500. Keep in mind I bought this only about 2 months ago. Basically, for the past 2 weeks, I have been experiencing con...
IBTwist
Just happened two more times today. Doing the same exact thing. Definitely seems like its resetting itself. Please give me any guidance on what to do, is this a settings issue, firmware issue, or is it just a hardware issue and does it need to be replaced??
Netduma-Fraser
Oct 13, 2020NetDuma Partner
Do you have it plugged into a power extender? If so plug directly into a wall outlet and see if that resolves it please.
- IBTwistOct 13, 2020Aspirant
No it is plugged in directly to a wall outlet and always has been. Probably asking an obvious question here, but if power is insufficient in a particular outlet, would that really just cause it to reset rather than power off completely? Seems interesting to me. Also, if I moved it to another outlet or another location in the house, would that theoretically fix the issue as well? Thanks.
- Netduma-FraserOct 14, 2020NetDuma PartnerI've seen it before yes. Yes please try that, it may be better in another location.
