Berke
Dec 04, 2024Initiate
Rapp Not Loading
Not a single RAPP loads for me, and my connection, now is erratic. Getting extremly slow speeds. I have version XR1000 1.0.0.64_1.0.49. I have tried to check new firmware but it says I have the late...
Berke
I also downgraded to XR1000 1.0.0.50_1.0.36, and still no luck. This is a really expensive paper weight if I am unable to use any of the tools.
- Netduma-FraserDec 05, 2024NetDuma PartnerUpgrade via 192.168.1.1/adv_index.htm and use that 74 file, if you're connected via WiFi you'll probably disconnect which is why you saw that crash, wait 5 minutes then connect and see if it has updated and you can access.
