mabu_x
Feb 29, 2020Aspirant
RAX120 with CM1200
Decided to upgrade my Orbi CBR40 to a RAX120 + CM1200. Got the CM1200 set up, registered and working with my laptop. I followed the directions ( re: powercycling the CM1200 and moving the cab...
- Mar 02, 2020
No. I wasn't trying to use Link or WAN aggregation... just a direct Cat5E connection between the RAX120 Internet/WAN port and the top Ethernet port of my CM1200. No other ports on the CM1200 were in use.
When using the Nighthawk app, the setup process would verify that the cables were hooked up correctly, but would fail when connecting to the Internet.
I hesitantly filed a case # with Netgear, which in hindsight, I should not have been hesitant about. I immediately got a response saying I should call in ASAP. I did and after 1 hour of debugging with the tech, he determined that it was a faulty device. He then gave me a case # for the return, and suggested I return the device to the retailer (Best Buy).
Best Buy took it back with no problem and offered me a full refund or an exchange. I took the exchange. Returned home with a new RAX120 and 20 minutes later, it was set up. Working flawlessly now.
The CM1200/RAX120 setup is replacing my ORBI CBR40 setup. Both cable speeds and wifi speeds have significantly improved.
Mar 01, 2020Guru - Experienced User
Are you trying to use link aggregation? If so, disable it. It hasn't been known to work the best.
Do you have anything else plugged into the CM1200? It has more ports but you can only use 1 of them (unless you have link aggregation) through charter home service. Business is a little different.
mabu_x
Mar 02, 2020Aspirant
