Tekblade
Dec 27, 2019Aspirant
RAX80 Lam speed capped at 350Mbps
Hello everyone, first time poster here... I have a RAX80. -Any device plugged into a lan port maxes at 300-350 Mbps. (using multiple speed tests, ookla, fast.com, ISP internal site for speedte...
Tekblade
Oh geez, now I look like a total idiot because of the typo in the subject... I assure you I know it should be LAN, not sure how I missed that... I changed the subject in the reply, but I don't think it will change the original subject.. :(
Netduma-Fraser
Dec 27, 2019NetDuma Partner
Hey, I'd recommend you post here as they'll be more able to help you: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
- TekbladeDec 27, 2019Aspirant
thanks for the suggestion, I just posted it there...
