mr_nguyen
Jul 12, 2022Aspirant
Cannot connect to router login after latest firmware update
Hi, I have a netgear XR1000 and after updating the latest firmware I can not login in to the router admin. I appreciate any thought and feedback on this issue.
- Jul 12, 2022
If you mean to say that you still cannot login to the router, could you please clear your browser's cache after the reset, you should then be met with the setup wizard when you try to access the router's admin interface.
mr_nguyen
Update: I performed a factory reset on the router, the problem is still there and I can login to the router.
Netduma-Liam
Jul 12, 2022NetDuma Partner
