yootzee
Jan 27, 2021Aspirant
Cannot Login Via Browser - XR500
To the admins, sorry if there is more than one post of this. My internet connection when down in the middle of submit, and it looks like there are duplicates. Greetings, I'm attempting to login...
Netduma-Fraser
Jan 27, 2021NetDuma Partner
No worries! Are you trying to connect using routerlogin.net or the LAN IP? Is there any difference in which one you use? You may need to do a factory reset by holding the reset button for 30 seconds, releasing then waiting 2 minutes before you access.
yootzee
Thanks for the reply Fraser. I'm connecting directly to the router IP, when connecting via browser. If connecting via the Nighthawk app through my android phone, the connection / management is fine. I realize the standard is to recommend a factory reset. However, it isn't a good time for me as i'm looking at spending a couple of hours setting up devices and custom settings (i.e. mac filtering, schedules) on the router again. The last config backup I have is pretty old, so I believe a good bit has changed.
- Netduma-LiamJan 28, 2021NetDuma Partner
Thanks for the information!
Is there any difference if you try to access the interface using routerlogin.net?
Is the device you're trying to access it on connected to the XR via wired or wireless? If wired, are you able to access it via wireless? In theory this shouldn't make a difference, I'm just curious as to why it works fine on a mobile device.
- yootzeeJan 28, 2021Aspirant
I primarily use a hardwired connection. But, was trying it via wireless as well. Both were failing. The only reason I can think of as to why I don't have a problem connecting via mobile is mabye something browser based. My phone is using the nighthawk app. Other than that, I use my netgear account via the nighthawk app vs. the local Admin account.
Concerning routerlogin.net option. On my hardwired system, no matter what I do, Firefox will redirect me to https://www.netgear.com/home/services/routerlogincom.html. Via Chrome, it'll resolve to the router. I'm prompted three seperate times for username / pwd, then I get into the mgmt console successfully. Same on my wireless laptop. Via Chrome, I'm prompted three times, then get into mgmt console. So, I'm not sure what that's all about. But, I get there so...
I've never used the routerlogin.net fqdn previously, and used direct IP. didn't even know (or remember) it was an option until now.
As much as I hate to do it, at some point I'll do a hard reset on the unit and reconfigure. I just don't have time to do it right now.
- Netduma-FraserJan 28, 2021NetDuma PartnerWhen did it first occur and do you recall changing any settings at all? You could make a new config when you manage to get on, do a reset and then restore it. The issue is you could bring back the issue by restoring the config.
