yootzee
Jan 27, 2021Aspirant
Cannot Login Via Browser - XR500
To the admins, sorry if there is more than one post of this. My internet connection when down in the middle of submit, and it looks like there are duplicates. Greetings, I'm attempting to login...
Netduma-Fraser
Jan 28, 2021NetDuma Partner
When did it first occur and do you recall changing any settings at all? You could make a new config when you manage to get on, do a reset and then restore it. The issue is you could bring back the issue by restoring the config.
yootzee
Jan 28, 2021Aspirant
Hard to say exaclty how long the problem may have been there. I haven't logged to the mgmt console in two or three months at least. I've had to restart the router a couple of times becuase my hardwired connections stopped comms. But, haven't changed any settings in 6 months. Things on my LAN don't change much, so once I get everthing setup and tweaked, I rarly mess with it. The only reason I was logging in yesterday when this started is that I'm dropping packets big time over the last week, and I need to start figuring out if its the routher or ISP. I agree with you on the config. I've already made a backup. But, when I do a reset, I'll just take some screen shots and hand jam everything back in. I've just gotta work around work schedules.
- Netduma-FraserJan 28, 2021NetDuma PartnerThat's fair enough, unfortunately there are no settings that influence the ability to login that you can change.
