Egodabossmane
Feb 20, 2025Aspirant
Re: Can't Reach This Page, then fixes itself after a second
Power light flashing white no internet connection how do I fix it no wifi connection either anyone got a solution to my problem need help ASAP.
- Feb 21, 2025Have you tried to access the interface/completed the Setup Wizard if it shows that when trying to access?
Egodabossmane
Power light flashing white no internet connection how do I fix it no wifi connection either anyone got a solution to my problem need help ASAP. I've turn it off for a week still nothing.
- Netduma-FraserFeb 21, 2025NetDuma PartnerHave you tried to access the interface/completed the Setup Wizard if it shows that when trying to access?
- EgodabossmaneFeb 22, 2025Aspirant
how do I do that I cant even connect to the router or wifi have no access at all
- Netduma-FraserFeb 23, 2025NetDuma PartnerYou said you don't have internet but you don't need internet to access the router. Connect your PC via ethernet and attempt to access the router at http://192.168.1.1 or http://10.0.0.1 or http://routerlogin.net
