Egodabossmane
Feb 20, 2025Aspirant
Re: Can't Reach This Page, then fixes itself after a second
Power light flashing white no internet connection how do I fix it no wifi connection either anyone got a solution to my problem need help ASAP.
- Feb 21, 2025Have you tried to access the interface/completed the Setup Wizard if it shows that when trying to access?
Netduma-Fraser
Feb 21, 2025NetDuma Partner
Egodabossmane
Feb 22, 2025Aspirant
how do I do that I cant even connect to the router or wifi have no access at all
- Netduma-FraserFeb 23, 2025NetDuma PartnerYou said you don't have internet but you don't need internet to access the router. Connect your PC via ethernet and attempt to access the router at http://192.168.1.1 or http://10.0.0.1 or http://routerlogin.net
- EgodabossmaneFeb 28, 2025AspirantOn my provider router I have connections and internet access but when I plug my XR500 to it I get nothing but white light flashing this is so frustrating out of nowhere it just stop working and I can't seem to find the fix.
- Netduma-FraserMar 02, 2025NetDuma PartnerCan you access while connected to the XR via any of the above URLs?
