bacevedo
Oct 29, 2019NETGEAR Employee Retired
Developer Blog 1: The Future of DumaOS: Version 3.0
Last year we released our first major update for DumaOS, Milestone 1.3. You guys loved it, so we quickly got to work on the next milestone, packing it full of features to make your Nighthawk P...
May 26, 2020Guru - Experienced User
Never seen an inconvience with my XR router pre and current CD19 events. Not sure why current events would cause problems with your router. Yes CD19 is causing slow downs for support. Goes for any router mfr and there support. Its effecting everything.
Did you even try reverting back FW versions or go with initial first version FW? Seems like more troubleshooting would be needed to really figure out where your problem is other than being inconvienced by the slow down which no can help you with currently. :smileytongue:
Netduma-Fraser
May 26, 2020NetDuma Partner
I'd suggest signing up for the beta here so that you can be one of the first to see if it resolves your issues: http://www.netgearinnovation.com/dumaos-beta/index.html
