bacevedo
Oct 29, 2019NETGEAR Employee Retired
Developer Blog 1: The Future of DumaOS: Version 3.0
Last year we released our first major update for DumaOS, Milestone 1.3. You guys loved it, so we quickly got to work on the next milestone, packing it full of features to make your Nighthawk P...
Netduma-Fraser
Dec 23, 2020NetDuma Partner
raghavan We're certainly putting it through its paces yes but we won't do anything for the R1 version that will unnecessarily put strain on it to the point where it would affect your connection. We can't upgrade the R1 hardware specifically as we don't own the hardware. However, we released a successor to the R1 - the R2, which is more powerful, optimized for DumaOS 3.0 and owned by us.
scotja50
Jan 04, 2021Aspirant
How can you say that? this whole project is just the router software version of cyberpunk at this point. wasted all your customers time and money.
- Netduma-FraserJan 04, 2021NetDuma Partnerscotja50 what are you referring to exactly? Are you having a specific issue we can help with?
- satinghostriderFeb 08, 2021Tutor
There has been some changes to the GeoFilter map where Singapore is now not there anymore. On the previous version, I could still peek and find Singapore and the cursor would turn white. With the latest update for the XR500, Singapore seems to be wiped off from the map. Yes we are very small but we are there. :(
Model : XR500
Firmware : V2.3.2.114
- Netduma-LiamFeb 08, 2021NetDuma Partner
Is this just for setting your home location or is this preventing you from joining a particular server?
