Mi7ooo
Jun 10, 2024Tutor
Re: DHCP constantly renewing XR500
Hi all, I also started getting the same dhcp lease renewal issue. Im using version 134. I have been using it for years but the past few weeks the router started having this issue. I tried settin...
- Jun 19, 2024Hi Fraser,
Yes i did that and the router seem to be working fine for now. I flashed version 114 using tftp, did factory rest and then upgraded to 134.
Thanks for the usual support.
MJ
Jun 10, 2024Guru - Experienced User
Try setting DHCP range from .100 to .200?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
