Mi7ooo
Jun 10, 2024Tutor
Re: DHCP constantly renewing XR500
Hi all, I also started getting the same dhcp lease renewal issue. Im using version 134. I have been using it for years but the past few weeks the router started having this issue. I tried settin...
- Jun 19, 2024Hi Fraser,
Yes i did that and the router seem to be working fine for now. I flashed version 114 using tftp, did factory rest and then upgraded to 134.
Thanks for the usual support.
MJ
Netduma-Fraser
Jun 10, 2024NetDuma Partner
Did you set the reserved IPs outside the range you set?
