Mi7ooo
Jun 10, 2024Tutor
Re: DHCP constantly renewing XR500
Hi all, I also started getting the same dhcp lease renewal issue. Im using version 134. I have been using it for years but the past few weeks the router started having this issue. I tried settin...
- Jun 19, 2024Hi Fraser,
Yes i did that and the router seem to be working fine for now. I flashed version 114 using tftp, did factory rest and then upgraded to 134.
Thanks for the usual support.
MJ
Jun 10, 2024Guru - Experienced User
Try setting DHCP range from .100 to .200?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Mi7ooo
Jun 15, 2024Tutor
Hi,
I tried the suggested solution, but the issue persists. The router stayed fine for a couple of days though
My modem is huawei hg8245w5.
I dont remember if i have done mf reset on the firmware.
Any tips ?
Any tips ?
- Netduma-FraserJun 15, 2024NetDuma PartnerDisable DHCP entirely (make sure you've reserved all the IPs) and then it should be better
- Mi7oooJun 16, 2024TutorHi Fraser,
Tried disabling dhcp, for some reason it didnt recognize all devices although they have been setup. Re-enabled dhcp again and them couldn’t connect at all to the router.
I did a factory reset and now the router cant boot up . I enter 192.168.1.1 , first time it took me to the license agreement, i accepted it then it got stuck. I used also adv_index but still the same. Did multiple factory resets with no luck. Also turned it off for 10 mins still the same.
I guess the router just died.- Netduma-FraserJun 16, 2024NetDuma PartnerUnplug it from power for 10 minutes, this will let the residual power drain, then plug in, wait 4 minutes and try accessing
