Mi7ooo
Jun 10, 2024Tutor
Re: DHCP constantly renewing XR500
Hi all, I also started getting the same dhcp lease renewal issue. Im using version 134. I have been using it for years but the past few weeks the router started having this issue. I tried settin...
- Jun 19, 2024Hi Fraser,
Yes i did that and the router seem to be working fine for now. I flashed version 114 using tftp, did factory rest and then upgraded to 134.
Thanks for the usual support.
MJ
Mi7ooo
Jun 15, 2024Tutor
Hi,
I tried the suggested solution, but the issue persists. The router stayed fine for a couple of days though
My modem is huawei hg8245w5.
I dont remember if i have done mf reset on the firmware.
Any tips ?
Any tips ?
Netduma-Fraser
Jun 15, 2024NetDuma Partner
Disable DHCP entirely (make sure you've reserved all the IPs) and then it should be better
