Check456
Nov 20, 2024Aspirant
Re: DumaOS not loaded yet! XR700 (no 2.4 or 5ghz wifi either)
The same thing happened to me and I have found a solution that has worked for me so I am sharing this with the community. I upgraded to the duma os 3.0 firmware for xr700 but it seemed buggy and ...
Nov 26, 2024Guru - Experienced User
Any progress on this?
I upgraded to the duma os 3.0 firmware for xr700 but it seemed buggy and I ended up with the dreaded '' Duma OS is loading wait 4 minutes.....''
I waited days to no avail.
I then managed to gain access via 192.168.1.1/adv_index.htm
I then downloaded a previous firmware XR700-V1.0.1.50.img
and uploaded this via the update section.
It fixed my issue and was able to log in properly.
The firmware which is the latest for my router was XR700-V1.0.1.50-0626.img
and was the culprit I believe causing these problems.
I have set up now on the older firmware (XR700-V1.0.1.50.img) which seems more stable and will wait for a patch to come out for it in the future before I decide to update it again.
I'm relieved because I actually thought my xr700 was bricked and after paying so much money for it.
Good luck folks and hope this helps you all. Any questions get in touch.
