Killhippie's avatar
Killhippie
Prodigy
Mar 05, 2018
Re entering new 'speeds'
Is it possible to have a simpler way to update your connection thoughput? A dedicated for want of a bttter term 'speed test' button in the set up section would be great, rather than running setup aga...
  • Netduma-Fraser's avatar
    Mar 05, 2018
    Yes, this is definitely something we want to add to a future version so it is on our roadmap. Thanks for letting us know you would like this feature
