my340i
Apr 12, 2022Apprentice
Extremely Slow XR500 Router
Hey All, I have an extremely slow Nighthawk XR500 (Tested on V2.3.2.130 and V2.3.2.134) that is of course out of warranty. I am paying for 900 mbps which I am getting when wired to my modem. Whe...
Netduma-Liam
Apr 28, 2022NetDuma Partner
Very strange, what were you using to test the speeds? A third-party speed test like speedtest.net?
Were you connecting the Laptop to the XR500 with the same cable that connects the AX2400 to the XR500? i.e, disconnecting the 2400 and connecting the laptop with that same cable?
my340i
Apr 28, 2022Apprentice
Right haha. I test 3 times and average them using https://www.speedtest.net/ , https://fast.com/ (always seems like its really low) and the built in speed test when you google speed test.
Yeah I did, I already see where you are going. I'll try out a couple cables.
- Netduma-FraserApr 28, 2022NetDuma PartnerKeep us posted!
- my340iApr 29, 2022Apprentice
2 different CAT6 cables
Laptop to tester
810mbps, 830mbps
Laptop Wired to XR500
540 mbps, 555 mbps
Went back to simple times again
Wired direct to modem 885 mbps
Modem to AX2400 to laptop 855 mbps
Modem to XR500 to laptop 532 mbps
- Netduma-FraserApr 30, 2022NetDuma PartnerRevert back to router mode then could you disable Port and DoS protection in WAN Settings, also set NAT to Open and see if you get faster speeds then please?
- my340iMay 02, 2022Apprentice
Negative on that one. I did also go back to disabling QoS since I have never seen a benefit to this feature.
- Netduma-LiamMay 03, 2022NetDuma Partner
Did you have these same issues prior to the full releases of DumaOS 3.0? For example, back on 2.3.2.114, did you have these issues? Or was this firmware before you picked up the XR500?
- my340iMay 03, 2022Apprentice
Nope, it unfortunately already had DumaOS. You know thinking back I had pretty close to these slow speeds since I got this router so I really don't think anything has changed much its just either a slow router or has a defect. I spent so much time from Comcast and having them do signal checks and improvements (service call) to replacing modems I just didn't put 2 and 2 together. Just kinda frustrating a close to $300 dollar router didnt last a couple years. I'm really kinda lost what to do now as I have used Nighthawk so long haha and theres no way Im using my companies hardware haha.
- Netduma-FraserMay 03, 2022NetDuma PartnerIt will always have had DumaOS but 3.0 is relatively new so depends when you purchased so worth trying one of the older versions to see whether it affects it at all: https://www.netgear.com/support/product/XR500.aspx#download
- my340iMay 09, 2022Apprentice
Tried 2 sub 3.0 firmwares and there was no noticeable change.
- Netduma-FraserMay 09, 2022NetDuma PartnerI'd suggest reupgrading the firmware using the TFTP method, this bypasses the boot process and any issues there then once done do a factory reset for the freshest install possible: https://kb.netgear.com/000059634/How-do-I-upload-firmware-to-my-NETGEAR-router-using-TFTP-from-the-Microsoft-Windows-Command-Prompt?article=000059634 then see if the speeds increase
- my340iMay 10, 2022Apprentice
On it, soon as works over today I'll give it a shot!
Also ordered a RK1 router through my work since I get them at cost so I will have a permeant router to test with too.
- my340iMay 12, 2022Apprentice
Process was straight forward and worked well. I used the test directly on the router as well so no options have been touched yet.
Also ran some speed tests using speedtest, fast, and integrated speed test when you google speed test. (448, 380, 396)
- Netduma-FraserMay 12, 2022NetDuma PartnerOkay that's not too bad considering what it has set the speeds at, make sure to set the speeds you pay for then disable QoS fully and see what you get.
- my340iMay 16, 2022Apprentice
Done and done
Its definitely going to be bad though considering I'm 2ft from the router and 2ft away testing on Wifi.
Testing wired right by the router, same 3 websites - 376, 385, 397
Testing just downstairs through one floor on 5ghz (I would say a total of 50ft) 285, 291, 311
Pretty close to giving up on this, really frustrating $250+ routers cant last 2 years and come with 1 year warranties.
- Netduma-FraserMay 17, 2022NetDuma PartnerI think it may be best at this point to contact Netgear directly and see if they can arrange a replacement for you: http://support.netgear.com/
- my340iMay 17, 2022Apprentice
I wish, if you arent in warranty you cant even talk to them.
" I cannot find an answer to my problem, I would like to contact NETGEAR support. Based on your serial number and purchase date, NETGEAR can offer you the following support options:
SEARCH KNOWLEDGEBASE
VISIT COMMUNITY"
- Netduma-FraserMay 17, 2022NetDuma PartnerAh that's unfortunate. Okay as a test put your PC in the DMZ on the XR (remove once you've done the test), re-enable QoS and make a Traffic Prio rule for the PC, 1-65535 source & destination, TCP/UDP then see what speeds you get
- my340iMay 18, 2022Apprentice
Can do, would you also enable ipv6 or leave it disabled as it is.
- Netduma-LiamMay 18, 2022NetDuma Partner
Please leave it disabled for now thanks
