ernieart
Sep 09, 2020Aspirant
FIFA on a XR500. how to better my ping?
So i mainly play fifa. in fifa in order to get the best gaming experience with less lag as well. you to have low ping. in fifa anything 30 ping or lower gets you into the full 5 bars of connection th...
Netduma-Fraser
Sep 10, 2020NetDuma Partner
Distance is your biggest enemy here because you can't get a closer server in order to get a lower ping. It may not be possible to get a ping under 30 for that server but you will need to use QoS to try and get it as low as possible, what are your expected/paid for speeds and what are your QoS settings?
ernieart
Sep 16, 2020Aspirant
i get 300 down speed. wired as well. all i have done is use the perimeter bubble to reach out to the portland server. i also always turn off anything using speed while playing fifa. these are the main things i do. im not to savvy with the router yet. first tiem user.
