ernieart
Sep 09, 2020Aspirant
FIFA on a XR500. how to better my ping?
So i mainly play fifa. in fifa in order to get the best gaming experience with less lag as well. you to have low ping. in fifa anything 30 ping or lower gets you into the full 5 bars of connection th...
Netduma-Fraser
Sep 18, 2020NetDuma Partner
So it is a pure modem with no other devices connected to it?
ernieart
Sep 18, 2020Aspirant
Yes. Modem from my provider. One cable from modem to router. That’s it.
- Netduma-FraserSep 18, 2020NetDuma PartnerYour trace does show a high ping so not sure how far you'll be able to get it down. What ping do you get direct from the modem?
