NetriX
Sep 11, 2018Aspirant
Firmware 2.3.2.32 Breaks Internet Speed
Firmware 2.3.2.32 breaks my internet speed. I run a 1Gbps Up/Down connection. With the latest firmware my speed tops out at 56 Mbps.
QOS is disabled and proper speed is set in Anti-Bufferbloat ...
Killhippie
Sep 17, 2018Prodigy
Enough that on this forum there would be a large amount of complaints, this router is not the kind bought by those that are not tech savy. Also this router is sold all over the world so it would be noticed. The disconnect thread was large enough to show that many people join these forums to voice concerns. I would relead the firmware again from the download link, the router will ask if you want to install the same version (corrupt installs happen) then do no factory reset and see how it goes.
OlegP
Sep 17, 2018Apprentice
I disagree. The tech savvy people are using Microtic router's or flashing custom firmware on their own routers. They aren't buying an off the shelf consumer router at their local Best buy.
This is the Leet Pro-gaming Win Button router that's marketed for the masses. It's sold as a set it and forget it type of device for the average Joe's.
I don't want to mess around with ports and packet headers when configuring QOS settings for games. That's why I bought into this product in the first place.
