blaisual
May 09, 2021Tutor
geofilter fail xr500 destiny
i have the firmware xr500 v2.3.2.114 but the geofilter does not working on the game destiny 2,does someone have a solution or know howto fix it. have already tried a lot and tried but nothing worked ...
Dunaz
May 11, 2021Guide
Great job guys, the router filters destiny perfectly thanks
Shaxi
May 16, 2021Aspirant
What settings are you using please
- Netduma-FraserMay 16, 2021NetDuma PartnerStylhz No, non puoi, questo serve per filtrare i server, non per abbinare solo / contro i compagni di squadra.
Shaxi place your radius over an area with servers and you will be able to force them.
