LightningByte
Aug 22, 2019Aspirant
Hidden (already saved) SSID wont show on Windows 10
Hi, Pain in the ass this Netgear, just switched from TP-link thinking I would make an upgrade (stupid paid YouTube ass "revievers", comercial useless crap is what I paid nearly 300 bucks for!!)... Th...
Netduma_Alex
Aug 23, 2019NetDuma Partner
Try some of the stuff on this page, I really do think it's a Windows problem:
https://troubleshooter.xyz/wiki/fix-windows-10-wont-remember-saved-wifi-password/
LightningByte
Aug 23, 2019Aspirant
Connected old TP-link again and it works normaly and shows already saved hidden SSID credentials straith away, just like it did before. So, It is not Windows, It´s damn Netgear...Spending 4th day now trying to get something to work where it should already work like a charm near that price tag!!! One really should shut down this YouTube crap "reviews"... This is plane simple untested crap, period! Bringing crap back to where it belongs buying new TP-Link!
- Netduma_AlexAug 23, 2019NetDuma Partner
Fair enough. I mean just because the old one works doesn't mean that it's not a windows problem. Perhaps the problem occured after you added the TP-Link details, so the old ones are unaffected by the bug.
