P111
Sep 19, 2021Luminary
How do I communicate with my modem?
I have a modem on the other side of my XR1000. The XR1000 replaced an old Asus router, which allowed me to talk right through it to the modem. Think is the XR does not. It was a really handy feature ...
P111
Sep 20, 2021Luminary
I also note that the upnp configuration does not work. If I set it to enabled, it doesn't stay that way.
P111
I checked out the subnet mask and it is correct. I have no idea why I can not commicate with the modem.
- Netduma-FraserSep 20, 2021NetDuma Partner
Have you put the Draytek in bridge mode or anything like that or is it still acting like a router? The UPnP checkbox is currently bugged but is enabled by default so youcan ignore that if it appears otherwise.
