RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
Shikwan68
Mar 19, 2019Star
Just installed the latest FW and am now using the Hybrid VPN with NordVPN. A few questions;
1. This should be configured with the nearest VPN server for the best connection/latency correct? The games I play will auto connect me to servers based on my VPN connect and not my real connect.
2. So If I use a VPN server outside of my Geo-Filter radius then I will have to reconfigure the radius, based on the location of the VPN server I connect to, right?
3. Hybrid VPN feature is something that I shouldn't use except if I'm experiencing DDoS attacks frequently since the connection increases latency and VPN servers tend to be slow?
4. Lastly, I connect to Xbox Live from behind a business firewall and I noticed thatmy NAT Type is now strict when I use the Hybrid VPN. It says; 'Double NAT detected'. So far it doesn't seem to affect my gaming...Should I put the Xbox on the DMZ to resolve this?
