ipponz
Oct 17, 2019Aspirant
I Have Hybrid VPN Set, But It Doesnt Work
I have a hybrid VPN set and also an account on pure*pn. According to settings on my Nighthawk Pro i'm connected to VPN. After this i add my PS4 to VPN traffic. When i do this and i test my ip addre...
- Oct 18, 2019
Well I know that Hybrid-VPN can produce slower speeds than your bandwidth would usually support. This is a combination of the fact that VPNs are just slower than a normal connection, and the fact that Hybrid-VPN cannot use the same amount of processing power that a desktop equivalent piece of software would be able to use.
As for why it is still showing your IP address... Did you forward ALL traffic, as in all ports TCP/UDP to the VPN?
Netduma_Alex
Oct 18, 2019NetDuma Partner
