JoeFI
Jan 15, 2021Apprentice
Kicked from dashboard
Hi, I keep getting kicked out of my router dashboard with the message I'm signed in from another device and to either continue or exit. The ex770 is on my network also. It has happened about once a m...
Netduma-Fraser
Jan 15, 2021NetDuma Partner
Do you usually access via routerlogin.net or the LAN IP (default 192.168.1.1)? Do you notice a difference connecting to either?
JoeFI
I use the router.net option. I've logged out of the app so I'll see if that works, so far so good. And if not I'll log on via ip address. Thanks
- JoeFIJan 18, 2021ApprenticeHi Fraser,
The issue hasn't occurred since I've started logging in via the ip address so it appears to be resolved.
Thanks
Joe- Netduma-LiamJan 18, 2021NetDuma Partner
OK that's good to hear!
Let us know if it re-occurs!
- JoeFIJan 18, 2021ApprenticeWill do.
Thanks
